Revision Control Search
The Revision Control Search portal allows users to search for entities that have a revision history. The Search By dropdown provides additional functionality so that users can search for revisions that are associated to theirs or other’s user ID. Users can also Check In, Force Check In, or Check Out one or more entities through this portal.
Zone Options
• Revision History Search allows the user to query for revised entities based on a combination of criteria.
◦ In the User ID field, enter the user ID that is associated with a revision.
◦ In the External Reference field, enter an ID from an external system and is associated with a revision.
◦ In the Maintenance Object dropdown menu, select the Maintenance Object that is associated with a revision. The options in this list are populated by the Maintenance Objects that are active to track revision.
◦ In the Key 1, Key 2, Key 3, Key 4, Key 5 fields, enter the primary identifier(s) for the revised entity. Typically, the entity only requires a single key, but some entities require more than one (for example, Oracle Utilities Customer Care and Billing SA Type require CIS Division and SA Type).
◦ In the Status dropdown menu, select the entity status for your search.
• Check In allows the user to search for entities currently checked out to the logged in user ID and a combination of criteria. Once the search results are returned, the user has the option to select one or more entities and check them in.
◦ In the Key field, enter the primary identifier(s) for the revised entity.
• Force Check In allows the user to search for entities that are currently checked out by other user IDs (excluding the logged in user ID) based on a combination of criteria. Once the search results are returned, the user has the option to select one or more entities and check them in.
◦ In the Checked Out By User field, enter the user ID that has the entity in a Checked Out status.
• Check Out allows the user to search for entities currently checked in user ID and a combination of criteria. Once the search results are returned, the user has the option to select one or more entities and check them out.
Please see Working with Revision Control Zones for more information about working with individual entities.
