Criteria Groups versus Eligibility Criteria
Before we provide concrete examples of eligibility criteria, we need to explain two concepts: Criteria Groups and Eligibility Criteria. A script's criteria groups control whether a user is eligible to choose a script. At a high level, it works like this:
• A criteria group has one or more eligibility criteria. A group's criteria control whether the group is considered true or false.
• When you create a group, you define what should happen if the group is true or false. You have the following choices:
◦ The user is eligible to choose the script
◦ The user is not eligible to choose the script
◦ The next group should be checked
We'll use the following example from Oracle Utilities Customer Care and Billing to help illustrate these points. Assume a script is only eligible if:
• The customer has electric service and the user belongs to user group A, B or C
• OR, the customer has gas service and the user belongs to user group X, Y or A
Example: Determining script eligibility criteria
This script requires two eligibility groups because it has two distinct conditions:
• IF (Customer has electric service AND (User belongs to user group A, B or C))
• IF (Customer has gas service AND (User belongs to user group X, Y or A))
If either condition is true, the script is eligible.
You would need to set the following criteria groups in order to support this requirement:
Group No.
Group Description
If Group is True
If Group is False
1
Customer has electric service and the user belongs to user group A, B or C
Eligible
Check next group
2
Customer has gas service and the user belongs to user group X, Y or A
Eligible
Ineligible
The following criteria are required for each of the above groups:
Group 1: Customer has electric service and the user belongs to user group A, B or C
Seq
Logical Criteria
If Eligibility Criteria is True
If Eligibility Criteria is False
If Insufficient Data
10
Check next condition
Group is false
Group is false
20
Group is true
Group is false
Group is false
Group 2: Customer has gas service and the user belongs to user group X, Y or A
Seq
Logical Criteria
10
Group is false
Group is false
20
Group is true
Group is false
Group is false
The next section describes how you might configure the specific logical criteria in each of the groups.
