Outbound Message Schema Validation
The outbound messages that are generated by the system should be well formed and valid so that they do not cause any issues in the external system. To ensure this validity you may configure the system to validate messages before they are routed to their destination. Note that the validation is applied just before communication with the sender and therefore after any Request XSL has been applied.
• Define a directory where the valid W3C schemas are located using the Message option Outbound Message Schema Location.
• Each external system message must indicate the appropriate W3C schema to use for validation.
You may turn on or off this validation checking using the Message option Schema Validation Flag.
This feature is not supported for cloud implementations.
