Next/Previous Item Buttons
Next/Previous buttons
The Previous Item and Next Item buttons appear in the Page Actions Toolbar under these conditions:
• You access a fixed page, meaning that it is not portal-based.
• You use a search page to display an item.
• There are multiple items in the search results list below or above the selected item.
If, for example, you enter search criteria of "Smith" on the User Search page, you might see the following results:
• Smith, Albert
• Smith, Peter
• Smith, Zane
If you select Smith, Peter, Peter's user information is displayed on the User page. If you then click the Next Item button, Smith, Zane will be displayed. In addition, because Smith, Zane is the last entry in the search results, the Next Item button is no longer needed and will not appear in the Page Actions Toolbar.
If you then click the Previous Item button, Smith, Peter will be displayed; click again and the Smith, Albert record will appear, and, because Smith, Albert is the first entry in the search results, the Previous Item button is no longer needed and will not appear in the Page Actions Toolbar.
Keyboard Shortcut
Alternate Shortcut
Alt+P
Alt+N
Alt+Shift+N
Refer to Shortcut Key Summary for information about the alternate shortcut.
