Maintaining Manufacturers
You use the Manufacturer portal is used to display and maintain manufacturers.
You can access the portal from Menu, then Asset Management, then Manufacturer. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
• Manufacturer: This zone displays the basic attributes of the manufacturer.
• Manufacturer Models: This zone displays a list of models associated with the manufacture. To add or edit models available for the manufacturer, click Edit in the zone title bar.
• Manufacturer Specifications: This zone displays a list of specifications associated with the manufacturer. Use the Specification portal to add or edit the specifications associated with the manufacturer.
