You can define additional processing that should happen when a case exits a given state. For example, you can have a
To Do entry automatically completed when a high bill complaint leaves the Decision Checkpoint state. This additional processing is held in algorithms that are plugged in on the case type and therefore you can define any type of additional processing.
