Correction Note (Bill - Bill Segments)
The Correction Note button is used to cancel and rebill bill segments and create a new bill that contains the cancellation and rebill details. We refer to the resultant bill as a correction note. Refer to Correction Notes - Presenting Correction Notes on a Separate Bill for more information. This button is enabled if:
the Correction Note option is specified on the Installation record AND
the bill is complete AND
the bill segment is frozen AND
there are no bill segment financial transactions that have been transferred out of the system.
When clicked, the Correction Note window opens.
You must specify the following parameters in the Correction Note window to correct the bill segment:
Cancel Reason defines why you are performing the correction.
Cutoff Date is the last possible day of each bill segments bill period. The current date defaults when the window opens. Refer to Ways To Control The End Date Of A Bill Segment for more information.
Accounting Date defines the financial period to which the corrected bill segments' financial transactions are booked. The current date defaults when the window opens.
Check Allow Estimates to indicate if Oracle Utilities Meter Data Management should estimate consumption if it cannot find a meter read.
Use the Billing Option to define how the system looks for meter reads:
Select Use Schedule if the system should select reads based on the SA's SP measurement cycle schedule.
Select Use Cut off Date if the system should only select reads from the end date of the existing bill segment.
If you prefer to have the system use the consumption details used on the original bill segments, check Use Old Read/Item/SQ. If this switch is on, neither Allow Estimates nor Billing Option is relevant.
The Use Old Read/Item/SQ switch is not available if the bill's SA references an SA type with a special role flag of Bill Determinants Required.
After specifying the parameters, click Calculate to correct the bill segments and create a correction note. The Bill Page opens and displays the Correction Note.
If you want to issue a correction note for an entire bill. You can create a correction note for ALL bill segments on a bill. To use this feature, display the bill in question on the Bill page and click the Correction Note button.
