Maintaining Settlement Transactions
You use the portal Settlement Transaction portal to view and maintain a settlement transactions.
You can access the portal from the Main > Settlement > Settlement Transaction. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
• Settlement Transaction: This zone displays basic information about the settlement transaction, including processing information and settlement calculation groups.
• Outbound Communication: This zone displays a list of outbound communications sent for the settlement transaction.
• Calculated Data Overview: This zone displays an overview of calculated data related to the settlement transaction.
• Calculated Data Details: This zone provides ability to query the detailed service quantity interval data for the settlement transaction.
A number of important actions are available for a settlement transaction depending on its status:
Action
Allowed Statuses
Details
Approve
Approval In Progress
Issue Detected (only when the exceptions are marked to require approval)
Allows a user to bypass any exception or failure message for the settlement transaction and attempt to send it to the requesting system.
Calculate
Pending
Allows a user to trigger settlement calculations.
Discard
Export Error
Issue Detected
Allows a user to discard the settlement transaction.
Export
Export Error
Allows a user to transition the settlement transaction to the Export status and send the settlement transaction to the recipients.
Export Manually
Export Error
Allows a user to manually export the settlement transaction send it to the recipients.
Override Exception
Issue Detected
Allows a user to override an exception and transition the settlement transaction to the Override Exception state.
Re-Calculate
Issue Detected
Reruns the entire process of calculation along with any validations (all settlement calculation rules) for the settlement transaction.
Supercede
Completed
Allows a user to indicate that the settlement transaction was corrected after being sent. Sets the status of the settlement transaction to Superceded.
