Outbound Message Type | Description | Message Sender |
D3-ADDMTRINV | Add Meter to Inventory | Message sender associated with the Add Meter to Inventory Outbound Message Type |
D3-COMMS | Commission Device | Message sender associated with the Commission Device Outbound Message Type |
D3-CONNECT | Connect Device | Message sender associated with the Connect Device Outbound Message Type |
D3-DECOMMS | Decommission | Message sender associated with the Decommission Device Outbound Message |
D3-DEMRESET | Demand Reset | Message sender associated with the Demand Reset Outbound Message Type |
D3-DERDEV | Deregister Device | Message sender associated with the Deregister Device Outbound Message Type |
D3-DISCONNEC | Disconnect Device | Message sender associated with the Disconnect Device Outbound Message Type |
D3-DVCSTSCHK | Device Status Check | Message sender associated with the Device Status Check Outbound Message Type |
D3-INITMRN | Initiate Meter Read by Meter Number | Message sender associated with the Initiate Meter Read By Meter Number Outbound Message Type |
D3-INITMTR | Initiate Meter Read by Meter Number | Message sender associated with the Initiate Meter Read By Meter Number Outbound Message Type |
D3-MTRADDNOT | Meter Add Notification Outbound Message Type | Message sender associated with the Meter Add Notification Outbound Message Type |
D3-MTREX | Meter Exchange Notification OB MSG | Message sender associated with the Meter Exchange Notification Outbound Message Type |
D3-MTRRMV | Meter Remove Notification | Message sender associated with the Meter Remove Notification Outbound Message Type |
