"Plain" XML Element | InitialLoadIMD element | Notes |
RecordType | N/A | |
Premise | N/A | |
ESIID | N/A | |
Provisioned | N/A | |
MeterID | dvcIdN | as is |
kWh | enQty | as is |
uom | KWH | |
TimeStamp | enDt | Convert to OUAF date/time format This should be mapped to enDt. Relevant only to non-interval data. |
Peak | enQty | as is A separate IMD Seeder will be created with <uom> in IMD Seeder populated with KW |
PeakDateTime | enDt | Convert to OUAF date/time format |
Dmd | enQty | as is A separate IMD Seeder will be created with <uom> in IMD Seeder populated with KW and 'Dmd' in "<mcIdN> |
TouA | enQty | as is A separate IMD Seeder will be created with <uom> in IMD Seeder populated with KWH and 'kWh Rate A' in "<mcIdN> |
TouB | enQty | as is A separate IMD Seeder will be created with <uom> in IMD Seeder populated with KWH' and 'kWh Rate B' in "<mcIdN> |
TouC | enQty | as is A separate IMD Seeder will be created with <uom> in IMD Seeder populated with KWH and 'kWh Rate C' in "<mcIdN> |
TouD | enQty | as is A separate IMD Seeder will be created with <uom> in IMD Seeder populated with KWH and 'kWh Rate D' in "<mcIdN> |
TouE | enQty | as is A separate IMD Seeder will be created with <uom> in IMD Seeder populated with KWH and 'kWh Rate E' in "<mcIdN> |
Volts | enQty | as is A separate IMD Seeder will be created with <uom> in IMD Seeder populated with Volts |
PF | enQty | as is A separate IMD Seeder will be created with <uom> in IMD Seeder populated with PF |
N/A | imdType | D1IL |
Origin | externalId | the origin element in "Plain" XML (incoming file name) |
N/A | serviceProviderExternalId | L+G This is a constant. There is no such field in incoming structure. |
RawData | rawData | Vendor-specific "raw" data When the "populateRawIMD" parameters in the EnvironmentSettings.xq file is set to true. |
