Inbound Web Services
Inbound web services define the details of how messages are received from an external system. This includes incoming usage and device events, as well as messages sent from the Silver Spring Networks UtilityIQ application in response to a command request.
The following inbound web services must be configured in your system. If these are not present in your configuration, add them. Refer to the Oracle Utilities Application Framework documentation for more information about creating inbound web services.
Inbound Web Service Name | Description |
D1-BulkRequestHeader | Bulk Request Header |
D1-BulkRequestUpdate | Bulk Request Update |
D1-BulkResponse | Bulk Response |
D1-DeviceEventSeeder | Device Event Seeder |
D1-DeviceStatusCheck | Device Status Check |
D1-InitialLoadIMD | Used by OSB to instantiate an IMD |
D1-PayloadErrorNotif | Payload Error Notification |
D1-PayloadStatistics | Payload Statistics |
D1-PayloadSummary | Payload Summary |
D7-ConnectDisconnectResponse | Connect Disconnect Response |
D7-GetStatusResponse | Get Status Response |
D7-MeterReadResponseInterval | SSN - Meter Read Response (Interval) |
D7-MeterReadResponseScalar | SSN - Meter Read Response (Scalar) |
D7-PingJobResponse | SSN - Ping Response |
Note: The following apply to all of the above inbound web services:
Message Options
• Trace: No
• Debug: No
• Active: Yes
Operations
• Operation Name: Same as web service name
• Schema Type: Business Object
• Schema Name: Applicable business object code
• Transaction Type: Add
Parent topic
