Property Name | Default Value | Description |
CB_CDCallbackEndpoint | http://[SERVER_NAME]/soa-infra/services/DG/ConnectDisconnect/CB_ServerService | The default endpoint to which MultiSpeak should send the asynchronous CB_Server callback. |
isExecutingCDReceivedCallout | true | Controls whether the Request Received callout executes. |
isExecutingCDCompletedCallout | true | Controls whether the Request Received Completed callout executes. |
isExecutingCDStatesChangedArrivedCallout | true | Controls whether the CD States Changed Notification arrival callout executes. |
CallbackTimeoutYears | 0 | The number of years to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service. |
CallbackTimeoutMonths | 0 | The number of months to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service. |
CallbackTimeoutDays | 0 | The number of days to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service. |
CallbackTimeoutHours | 0 | The number of hours to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service. |
CallbackTimeoutMinutes | 0 | The number of minutes to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service. |
CallbackTimeoutSeconds | 45 | The number of seconds to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service. |
Composite | Description |
ConnectDisconnectService | Entry point for the ConnectDisconnect operation. After a synchronous reply, further updates will be sent to the specified location asynchronously using DG-ConnectDisconnectStateChgNotification. |
CB_ServerService | MultiSpeak WSDL hosted to receive asynchronous CDStatesChangedNotification callbacks from the head end system. |
CB_ServerCallout | Reference describing the process callout used when the asynchronous callback from the head end system arrives. |
CD_ServerCallout | Reference describing the process callout. |
CD_ServerProxy | Reference describing the proxy used to invoke the head end system. |
AuxiliaryRoutines | Reference to common helper routines in the Common composite. |
DG-ConnectDisconnectStateChgNotification | A reference to an inbound web service capable of processing asynchronous results from a Connect/Disconnect request. |
