Property Name | Default Value | Description |
CB_ServerCallbackEndpoint | http:/[SERVER_NAME]/soa-infra/services/DG/OnDemandRead/CB_Server | The default endpoint to which MultiSpeak should send the asynchronous CB_Server callback |
IsExecutingOnDemandReadRequestReceived | true | Controls whether the Request Received callout executes |
IsExecutingOnDemandReadRequestReceivedResponse | true | Controls whether the Request Received Completed callout executes |
IsExecutingReadingChangedNotification | true | Controls whether the Reading Changed Notification arrival callout executes |
CallbackTimeoutYears | 0 | The number of years to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service. |
CallbackTimeoutMonths | 0 | The number of months to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service. |
CallbackTimeoutDays | 0 | The number of days to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service. |
CallbackTimeoutHours | 0 | The number of hours to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service. |
CallbackTimeoutMinutes | 0 | The number of minutes to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service. |
CallbackTimeoutSeconds | 45 | The number of seconds to await a response from the MultiSpeak server. This property only takes effect when the expTime element is not supplied in the input to the service. |
Composite | Description |
OnDemandReadService | Entry point for the OnDemandRead operation. After a synchronous reply, further updates will be sent to the specified location asynchronously using DG-ReadingChangedNotification. |
CB_ServerService | MultiSpeak WSDL hosted to receive asynchronous ReadingChangedNotification callbacks from the head end system. |
MR_ServerProxy | Reference describing the proxy used to invoke the head end system to initiate a On Demand Read. |
MR_ServerCallout | Reference describing the process callout used when initiating a On Demand Read. |
CB_ServerCallout | Reference describing the process callout used when the asynchronous callback from the head end system arrives. |
AuxilaryRoutines | Reference to common helper routines in the Common composite. |
DG-ReadingChangedNotificationXAI | A reference to an inbound web service capable of processing asynchronous results from a On Demand Read request. |
