Notes on Applicability of Fields and Field Values
Oracle Utilities Rate Cloud Service is based on the rate calculation functionality of Oracle Utilities Customer To Meter. However, not all fields and field values available to Customer To Meter are used with Rate Cloud Service. For some specific portals, some tabs, fields, and field values may not be applicable.
The following sections provide a summary, for specific portals, of the tabs, fields, and field values that may not be applicable when using Oracle Utilities Rate Cloud Service.
Portals Accessed via the Main Menu
Rate Schedule
Fields that are not applicable
Meter Configuration Type
Bill Message
Start Date
End Date
Field values that are not applicable
For Allow Estimates: 'No'
Calculation Rule
For Apply To calculation rule business object
Execution Option
For Calculate Service Quantity calculation rule business object
Execution Option
Characteristic Value
Contract Quantity
Historical Service Quantity
Previous Quantity
For Summary calculation rule business object
Execution Option
Fields values that are not applicable
For Service Quantity calculation rule business object
GL Statistical Qty: 'Yes'
For Stepped Service Quantity calculation rule business object
For all applicable calculation rule business objects
Criteria Field Type: 'Contract Quantity' and 'Historical Quantity'
On the Main tab
Portals Profile User ID
Favorite Profile User ID
Lower Age Limit for Yellow Bar
Upper Age Limit for Yellow Bar
Calculation Rule business objects that are not applicable
Apply VAT to Cross Referenced Charges
Calculate Climate Charge Levy and Relief Charges
Copy SQ from Master Bill Segment
Determine Demand Value to Price
Get Sub-Usage Request SQ
Math
Miscellaneous Charges
Bill Factor
On the Main tab
Tax Exemption
Value in Contract Term
Contract Rider Applicability
Use Sub SA Contract
Terms of Service Usage
On the Main tab
Bill Factor Type: 'Interval' and 'Time of Use'
Rate Check
On the Main tab
Service Agreement
Bill Segment
Service Point ID
Portals Accessed via the Admin Menu
User
Tabs that are not applicable
To Do Roles, Access Security, Portal Preferences, Favorite Links, Favorite Scripts, and Miscellaneous
On the Main tab
Installation Options - Framework
Message, Accessible Modules, and Installed Products
On the Main tab
Country
Seasonal Time Shift
Account, C&C, and Installed Products
On the Main tab
Quick Add Tender Type
Start Balance Tender Type
Create Field Activity Start Stop
Campaign
On the Person tab
Identifier Type (Person)
Identifier Type (Business)
On the Billing tab
Minimum Amount for Final Bill
User Can Override Bill Date
Base Time
Start Day Option
Use Alternative Bill ID / Alternative Bill ID Option
Bill Correction Option
On the Financial Transaction tab
GL Batch Code
A/P batch Code
Characteristic Type
On the Main tab
FK Reference
Allow Search By Char Value
On the Main tab
For Type of Char: 'File Location Value' and 'Foreign Key Value'
Distribution Code
On the Main tab
CIS Division
SA Type
Override Switch
On the Main tab
For Use for Non-Accrual Accounting - 'Checked' option
Device Type
Item Business Object
Consumption Source
UOM
Device Type Service Quantity MO
Summarized Badged Items
Track Location
Device Configuration Type
For Use Estimate - 'Checked' option
For Summarize for Billing - 'Checked' option
For Multi-Equipment Assign - 'Checked' option
For Billable - 'Checked' option
Unit of Measure
Decimal Positions
Base Unit of Measure
For Allowed on Measuring Component - 'Yes'
