Notes on Applicability of Fields and Field Values
Oracle Utilities Rate Cloud Service is based on the rate calculation functionality of Oracle Utilities Customer To Meter. However, not all fields and field values available to Customer To Meter are used with Rate Cloud Service. For some specific portals, some tabs, fields, and field values may not be applicable.
The following sections provide a summary, for specific portals, of the tabs, fields, and field values that may not be applicable when using Oracle Utilities Rate Cloud Service.
Portals Accessed via the Main Menu
  • Rate Schedule
    • Fields that are not applicable
      • Meter Configuration Type
      • Bill Message
      • Start Date
      • End Date
    • Field values that are not applicable
      • For Allow Estimates: 'No'
  • Calculation Rule
      • For Apply To calculation rule business object
        • Execution Option
      • For Calculate Service Quantity calculation rule business object
        • Execution Option
        • Characteristic Value
        • Contract Quantity
        • Historical Service Quantity
        • Previous Quantity
      • For Summary calculation rule business object
        • Execution Option
    • Fields values that are not applicable
      • For Service Quantity calculation rule business object
        • GL Statistical Qty: 'Yes'
      • For Stepped Service Quantity calculation rule business object
      • For all applicable calculation rule business objects
        • Criteria Field Type: 'Contract Quantity' and 'Historical Quantity'
      • On the Main tab
        • Portals Profile User ID
        • Favorite Profile User ID
        • Lower Age Limit for Yellow Bar
        • Upper Age Limit for Yellow Bar
    • Calculation Rule business objects that are not applicable
      • Apply VAT to Cross Referenced Charges
      • Calculate Climate Charge Levy and Relief Charges
      • Copy SQ from Master Bill Segment
      • Determine Demand Value to Price
      • Get Sub-Usage Request SQ
      • Math
      • Miscellaneous Charges
  • Bill Factor
      • On the Main tab
        • Tax Exemption
        • Value in Contract Term
        • Contract Rider Applicability
        • Use Sub SA Contract
        • Terms of Service Usage
      • On the Main tab
        • Bill Factor Type: 'Interval' and 'Time of Use'
  • Rate Check
      • On the Main tab
        • Service Agreement
        • Bill Segment
        • Service Point ID
Portals Accessed via the Admin Menu
  • User
    • Tabs that are not applicable
      • To Do Roles, Access Security, Portal Preferences, Favorite Links, Favorite Scripts, and Miscellaneous
      • On the Main tab
  • Installation Options - Framework
      • Message, Accessible Modules, and Installed Products
      • On the Main tab
        • Country
        • Seasonal Time Shift
      • Account, C&C, and Installed Products
      • On the Main tab
        • Quick Add Tender Type
        • Start Balance Tender Type
        • Create Field Activity Start Stop
        • Campaign
      • On the Person tab
        • Identifier Type (Person)
        • Identifier Type (Business)
      • On the Billing tab
        • Minimum Amount for Final Bill
        • User Can Override Bill Date
        • Base Time
        • Start Day Option
        • Use Alternative Bill ID / Alternative Bill ID Option
        • Bill Correction Option
    • On the Financial Transaction tab
      • GL Batch Code
      • A/P batch Code
  • Characteristic Type
      • On the Main tab
        • FK Reference
        • Allow Search By Char Value
      • On the Main tab
        • For Type of Char: 'File Location Value' and 'Foreign Key Value'
  • Distribution Code
      • On the Main tab
        • CIS Division
        • SA Type
        • Override Switch
      • On the Main tab
        • For Use for Non-Accrual Accounting - 'Checked' option
  • Device Type
      • Item Business Object
      • Consumption Source
      • UOM
      • Device Type Service Quantity MO
      • Summarized Badged Items
      • Track Location
      • Device Configuration Type
      • For Use Estimate - 'Checked' option
      • For Summarize for Billing - 'Checked' option
      • For Multi-Equipment Assign - 'Checked' option
      • For Billable - 'Checked' option
  • Unit of Measure
      • Decimal Positions
      • Base Unit of Measure
      • For Allowed on Measuring Component - 'Yes'
