Alerting On A Batch Job Stream
To receive alerts on an active batch job stream, edit the batch job stream and add the desired level of service algorithm on it.
Only algorithm types are delivered for Batch job stream level of service algorithms. A corresponding algorithm must be created before it can be added onto the batch job stream
Following level of services are currently supported on batch job streams
• Batch Job Stream has not started within ‘X’ minutes
• Batch Job Stream has failed
• Batch Job Stream ran too long (relative run)
