Conversion Batch Controls
The following batch controls are delivered with base product:
Batch Control
Description
K1-CNVLD
Conversion - Load Data using SQL Loader.
This process facilitates the legacy data extract upload using SQL Loader. The input data files are expected to be uploaded to a file storage location. See Input and Output File Location for more information about file storage locations.
One run uploads the data into a single target Table or Maintenance Object.
The process is multi-threaded.
This process is discussed in more details in the Data Load Batch chapter
K1-CNVDS
Conversion - Disable Conversion
This process resets the environment indicators and prevents further conversion activities. Once conversion is disabled, the following actions are blocked:
• Switching between Conversion and Production
• Table truncation
• Disable Indexes and Rebuilding the Statistics
• Data insertion into Production
• Data upload into staging
The process should be executed only once and only after all of the conversion activities are completed and the application is ready for the real production use.
K1-CNVEN
Conversion - Enable Conversion
This process resets the environment indicators and enables it for conversion activities. It should be executed at the start of the Conversion project.
K1-DRPIN
Conversion - Disable Indexes on Production Tables
This process can be used in two modes:
• Populate Table or Maintenance Object batch parameter to process specific object
• If no specific target is populated, the process disables indexes on all converted tables in Production schema
K1-SDSIN
Conversion - Disable Indexes on Staging Tables
• If no specific target is populated, the process disables indexes on all converted tables in Staging schema
K1-RIUSP
Conversion - Rebuild Indexes and Update Statistics in Production
• If no specific target is populated, the process rebuilds indexes and updates statistics on all converted tables in Production schema
• Specify the sampling size (percentage) for statistics gathering. If not specified, the system will use default dbms_​stats.auto_​sample_​size.
• Specify whether you wish to rebuild indexes, to gather table statistics or both.
It is recommended to rebuild the indexes and update statistics right after the data upload.
K1-RIUSS
Conversion - Rebuild Indexes and Update Statistics in Staging
• If no specific target is populated, the process rebuilds indexes and updates statistics on all converted tables in Staging schema
K1-CLNTB
Conversion - Truncate Tables in Production
• If no specific target is populated, the truncates all converted tables in Production schema
K1-SCLTB
Conversion - Truncate Tables in Staging
• If no specific target is populated, the truncates all converted tables in Staging schema
K1-CLNRT
Conversion — Truncate XML Resolution Tables
This process is allowed to run only in the Staging schema and may be used in two modes:
• If no specific target is populated, the truncates all XML Resolution tables in Staging schema
K1-CLNKY
Conversion - Truncate Key Reference Tables
• If no specific target is populated, the truncates all Key Reference tables in Staging schema
