Conversion Input Data Specifications
The system will generate a text file with data specification instructions for each of the conversion tables that are supported by the base product.
The specification files are for reference ONLY and are not used by the system at run time. These files describe the data format for each table so that the data specified can be loaded correctly with the Control File that is also generated by the system.
Parent topic
