Multiple Data Files
The large volume of the converted data may require the extract to be split into multiple parts.
In this case the multi-part extract for a target staging Table or Maintenance Object is loaded with a multi-threaded batch run.
Sample scenario:
10M of the Person records are being converted. The extract file is split into 10 files, PERSON1, PERSON2 PERSON3 etc., each file contains 1M records. All 10 files are uploaded to the input file location.
Batch process ‘Load Person data’ is submitted with 5 threads; each thread picks up 2 files and uploads the data into staging tables.
