Customizing the Integration
The product is delivered with out-of-the-box support for
Just in Time User Provisioning
with
Coarse-Grained Authorization
. Possible customization scopes are:
Customize the default access level for
. See
Override Default Access Level
for details.
Configure the
with
Fine-Grained Authorization
Override Logic to Determine Template User
Parent topic
Configuring Identity and Access Management Integration
This site works best with JavaScript enabled
