Override Logic to Determine Template User
The algorithm that determines the Template User is implemented as a pre-processing algorithm that determines the Template User on the F1-IDMUser. business object.
To override the logic used to determine the template user:
• Create a custom algorithm type and algorithm and use custom logic to determine the Template User for provisioning.
• Deactivate the existing product algorithm and specify the custom algorithm instead. Note that the algorithm that determines the Template User should be plugged before the algorithm that populates the data from the Template User.
Parent topic
