Oracle Cloud Object Storage
Oracle Cloud Object Storage (Object Storage) is a part of Oracle Cloud Infrastructure Storage Services.
Oracle Cloud Object Storage can be accessed and managed using Oracle Cloud Infrastructure Console or programmatically using Command Line Interface (CLI), REST APIs or Java. The Object Storage that is used by the system is owned and managed by customers.
Oracle Utilities Cloud Services use Object Storage as the file storage location for all file related integrations. Batch processes that need to read or write files as input will access Object Storage.
The system requires some configuration in order to allow it to connect to the Object Storage and have access to the files that need to be processed by it. The following chapter describes the required configuration in order to connect to Object Storage as well as provides information on how to reference files in Object Storage in batch processes.
Please refer to Oracle Cloud Infrastructure documentation for more information on Object Storage.
Parent topic
