Field | Comments |
Redaction Rule | Identifier for rule. Must be prefixed with CM for custom Redaction Rules to avoid conflicts with base provided rules |
Description | Short description for rule |
Field Source Type | Source of field. Valid Values: • Physical Field. Field definition on a particular table. • Referenced Field. Set to apply to field across tables. • XML Storage. Element within CLOB. |
Redaction Function | Redaction function to apply |
Table | Table Name for Field. Table must be defined as a Table object |
Field | Field Name on Table. Field must be defined to Table on the specified Table object |
Filter Expression | SQL WHERE Filter for field values to limit usage of redaction if necessary. For example: OWNER_FLG = 'CM' AND… The filter is limited to fields on the table. Leaving this value blank applies redaction to all values of the field. |
Reference Field | Reference Field to apply redaction to. |
XPath Expression | The XPath expression to determine the field in the CLOB to apply the rule to |
