Configuring a New Batch Scheduler Batch Control
In order to configure a new Batch Scheduler Batch Control, from the Admin menu, select Batch Operations, and select Batch Scheduler Batch Control. Use the Batch Scheduler Batch Control portal to search for and view existing batch scheduler batch controls.
A Batch Scheduler Batch Control is an entity that holds details of a batch control. Typically a scheduler batch stream definition is defined with batch control specified directly on it. In this case the batch parameters on the batch control are used in batch job submissions. A Batch Scheduler Batch Control can be created when batch parameters need to be customized different from the default batch parameters. The Batch Scheduler Batch Control can then be used on the Scheduler Batch Stream Definition. Only active batch scheduler batch controls can be used on the Scheduler Batch Stream Definition.
Parent topic
