| File Type | File Name |
| Single data file per Maintenance Object, no CLOB | File name equal target maintenance object name, i.e. PREMISE |
| Single data file per Maintenance Object, single CLOB column in the table, CLOB data in secondary file | Primary file name equal maintenance object name, i.e. PREMISE Secondary files name composed as maintenance object name concatenated with table name concatenated with ‘_CLOB’. For example, if PREMISE’s CI_PREM table contains CLOB, the secondary file name is: PREMISE_CI_PREM_CLOB |
| Single data file per Maintenance Object, multiple CLOB columns in the table, CLOB data in secondary file | Primary file name equal maintenance object name, i.e. PREMISE For each CLOB column being uploaded, the secondary files name composed as maintenance object name concatenated with table name concatenated with CLOB column name concatenated with ‘_CLOB’. For example, if PREMISE’s CI_PREM table contains two CLOB columns COL1 and COL2 , the secondary file names are: PREMISE_CI_PREM_COL1_CLOB, PREMISE_CI_PREM_COL2_CLOB |
| Multiple data file per Maintenance Object, no CLOB | File name is composed as target maintenance object name concatenated with file number, i.e. PREMISE1, PREMISE 2 etc |
| Multiple data file per Maintenance Object, single CLOB column in the table, CLOB data in secondary file | Primary file name is composed as target maintenance object name concatenated with file number, i.e. PREMISE1, PREMISE 2 etc Secondary files name composed as maintenance object name concatenated with table name concatenated with ‘_CLOB’ concatenated with file number. For example, if PREMISE’s CI_PREM table contains CLOB, the secondary file names are: PREMISE_CI_PREM_CLOB1, PREMISE_CI_PREM_CLOB2, etc |
| Multiple data file per Maintenance Object, multiple CLOB columns in the table, CLOB data in secondary file | Primary file name is composed as target maintenance object name concatenated with file number, i.e. PREMISE1, PREMISE 2 etc For each CLOB column being uploaded, the secondary files name composed as maintenance object name concatenated with table name concatenated with column name concatenated with ‘_CLOB’ concatenated with file number. For example, if PREMISE’s CI_PREM table contains two CLOB columns COL1 and COL2 , the secondary file names are: PREMISE_CI_PREM_COL1_CLOB1, PREMISE_CI_PREM_COL1_CLOB2, PREMISE_CI_PREM_COL2_CLOB1, PREMISE_CI_PREM_COL2_CLOB2 etc |
