Creating an Infrastructure Process
To create a new process, navigate using Admin > Implementation Tools > Infrastructure Process. Use the Infrastructure Process Query to search for an existing process. One an Infrastructure Process is selected, you are brought to the maintenance portal to view and maintain the selected record.
The following points provide information about creating a new Infrastructure Process.
Infrastructure Process references an Infrastructure Process Type. When creating a new process you need to select the type that the process will be based on.
The Name of the process is used for tracking purposes. The name doesn’t have to be unique in the system.
The Process Steps list is read-only and represents the steps that were configured on the Infrastructure Process Type.
Changing information on the Infrastructure Process Type, including the steps, will not affect existing Infrastructure Process records.
The Process Details section represents additional information that is required according to the corresponding process type definition.
Parent topic
