How to Customize
Configurations can be amended on several levels:
• To modify the configuration globally, amend the default Conversion Instructions (Conversion Task Type) that is referenced on Conversion Data Upload Master Configuration
• To modify the option globally for all tables, amend the default Conversion Instruction for Table (Conversion Task Type) that is referenced on Conversion Data Upload Master Configuration
• To modify the option globally for all maintenance objects, amend the default Conversion Instruction for MO (Conversion Task Type) that is referenced on Conversion Data Upload Master Configuration
• To modify the option for a specific table(s) or maintnance objects, create new Conversion Instruction (Conversion Task Type) and add the Override Instruction for Table or MO on Conversion Data Upload Master Configuration
• To make a non-converted table eligible for conversion, add it to the Override Conversion Eligibility list on Conversion Data Upload Master Configuration
IMPORTANT! Regenerate Conversion Artifacts to apply the configuration changes. Download the updated input file specifications.
