Other Object Types
While the focus of this guide is custom tables and custom Java code, there are potentially other customization object types that need to be remediated before moving to the cloud. The table below outlines support and non-supported extension types that need to be addressed as part of a migration:
Object Type
Description
Remediation Advice
Database Sequences
Sequences stored on the database used for identifier or other processing
Migrate code to use F1-DocumenSequenceAddUpd business service for sequence maintenance
JSP
These are code-complete screens written exclusively in JSP format
These need to be migrated to use UI Maps with simplified JSP code
JSP User Extensions
These are code snippets for legacy JSP based screens to override behavior on those screens
Not supported at the present time
FILE-PATH
Specifications of raw directories on the machine for batch processing. For example, directories to read or write files
Migrate to use aliases using the Cloud Object Storage Adapter
Environment Settings
Settings in various files in the architecture
Not supported as service provides the environment preconfigured.
Custom Threadpool definitions
Settings and architecture of batch execution threadpools
Migrate to use DEFAULT
Configuration Data (Admin Menu)
Administration menu data
Migratable using Content Migration Assistant
PL/SQL Code
Custom pl/sql functions
Not supported for security reasons
Triggers
Custom code on database
Other database objects
Other database objects that are not listed in the Custom Table support
Not supported
Linux/Unix Scripts
Custom scripts to manage the service
Not supported as service takes on that responsibility
Custom WS-Policies
Custom policies for inbound and outbound integration
Not supported as service provides prebuilt security
Oracle Web Services Manager policies
Web Service Manager policies for inbound and outbound integration
Oracle WebLogic Domain configuration
Domain Configuration for WebLogic
Not supported as service has prebuilt architecture
Custom Logo
Custom logo on service
Use Domain name for environment identification. Custom Logos are not supported as rebranding is not supported.
Custom Product Name
Custom name of product on top of screens
Not supported
