Context Type | Context Value (Sample Values) | Description |
HTTP Header | soapAction="process” | Get the value from the soap:operation in the WSDL Example: <wsdl:operation name="Get_APPT_SVC"> <soap:operation soapAction="process"/> |
HTTP Login User | Username | User ID to access the service |
HTTP Login Password | Password | Password to access the service |
HTTP Method | POST | |
HTTP Timeout | 60 | |
HTTP Transport Method | SendReceive | |
Message Namespace URI | http://oracle.com/GetApptMessage | Get the value from the schema namespace in the WSDL. This entry should be defined when the External System - Outbound Message Type - Namespace Option is set to Configured on the Message Sender |
HTTP URL 1 | @EXT_PUB@ server:port/servicename | The value should follow the format below: @EXT_PUB@server:port/servicename where: @EXT_PUB@ refers to the outbound proxy and append the endpoint url without the https:// protocol. Get the endpoint url value from the soap:address location in the WSDL Example: <wsdl:service name="receiveApptReq_PortType"> <wsdl:port name="receiveApptReq_PortType_pt" binding="receiveApptReq_PortType_binding"> <soap:address location="https://server:port/servicename"/> |
SOAP Insert Timestamp (Y/N) | Y | This is only needed when the wsdl policy of the service being invoked is wss_username_token_service policy or any policy that require a timestamp. |
HTTP URL 1 | @EXT_PUB@RESTEndpointURL | The value should follow the format below: @EXT_PUB@RESTEndpointURL where” @EXT_PUB@ refers to the outbound proxy and append the REST endpoint url without the https:// protocol. |
