Java Script Support
The Configuration Tools and legacy screen utilities used by the Oracle Utilities Application Framework supports a wide range of standards, but for security reasons use of Java script is restricted in certain circumstances to prevent injection.
The table below outlines which objects allow HTML formatting and Javas Script.
Component
Allows HTML formatting
Allow Java Script
UI Maps
Yes
Yes
Script Steps
Yes
Yes
Display Step in BPA
Yes
Yes
Object Description
Yes
No
FK Ref (UI Maps and Data Explorers)
Yes
No
FK Ref (legacy pages)
No
No
Data Explorer
Yes
No
Help Text
Yes
No
Others
No
No
All HTML code is run through the product HTML sanitization via the F1-HTMLWhitelist.
