Pre-Defined Application Roles
The roles listed below are pre-defined in the Applications that represent Oracle Utilities service environments. Each role represents an entitlement within the environment and grants user an access to a certain component.
New roles may be added with future releases as the Oracle Utilities Cloud Services are expanded into new functional areas.
Application Role
Authorized Access
Online Application User
Users assigned to this role may access online application.
Web Services Access
Users assigned to this role is authorized to access the REST/SOAP API-s.
BI Consumer
Users assigned to this role may access the Analytics Publisher within the environment and view and execute pre-defined reports.
BI Content Author
Users assigned to this role may access the Analytics Publisher within the environment and author new and view/execute existing reports.
Test Administrator
Users assigned to this role may access the Utilities Testing Accelerator within the environment and perform administrative tasks as well as develop and approve other's work.
Test Approver
Users assigned to this role may access the Utilities Testing Accelerator within the environment and develop and approve Test Components and Test Flows.
Test Developer
Users assigned to this role may access the Utilities Testing Accelerator within the environment and develop Test Components and Test Flows.
SQL Developer Web Online User
Users assigned to this role may access the Database Actions online and query the database to retrieve the information from both production and conversion schema
REST Enabled SQL
Users assigned to this role may use cURL utility to invoke REST services and query the database to retrieve the information from both production and conversion schemas.
SGG Test Harness User
Users assigned to this role may access the Smart Grid Gateway Cloud Test Harness provided with Oracle Utilities Meter Solution Cloud Service and Oracle Utilities Customer Cloud Service.
Note: Additional pre-defined roles for Oracle Utilities Analytics Visualization may be provided with specific cloud services. Examples include CustomerContentCreator. CustomerContentConsumer among others.
