Target Object | Sample Description |
Interval Data Set (INT_DATA_SET) | Regular maintenance object, CLOB field as a secondary file. Configuration: Conversion Task Type K1-CNV-MO Multiple data files (3) |
MO Customer Contact (CUST_CONTACT) | Regular maintenance object, CLOB fields in the main file. Configuration: same as Conversion Task Type K1-CNV-TABLE, but the CLOB as Secondary File indicator set to false. |
Table Meter Read (CI_MR) | Regular table, CLOB field as a secondary file. Configuration: Conversion Task Type K1-CNV-TABLE. |
Table Adjustment (CI_ADJ) | Regular table, CLOB field in the main file. Configuration: same as Conversion Task Type K1-CNV-TABLE, but the CLOB as Secondary File indicator set to false. |
Table Initial Sync Request (F1_SYNC_REQ_IN) | Table with Multiple CLOBs as secondary files. Configuration: For table with multiple CLOBs, the special Conversion Task Type was created based on the K1-ConvArtMultClobTblTaskType business object. Override Control File (Managed Content) was created and used as a custom Control File. Review the sample and note that there is a conditional input data selection. Only records with BO = W1-CompositeSyncReqGISAsset would be uploaded. A custom Control File is necessary if you have a requirement to manipulate the data during upload. Input Data File Specification: Since the Control File is fully custom, including the field list, the generated specification is describing expected file name(s) only. The data field formats, delimiters, sizes, and any other information related to the Input Data File layout should be determined based on the custom Control File. |
