Creating a File Export Batch Process
Oracle Utilities cloud services provide a way to extract system information into a file using a file-export batch process. This process can be configured to export and store extracted files in an Object storage location.
Oracle Utilities cloud services provide a sample Batch Control (F1-PDBEX) which supports file export functionality and which can be used as 'template' to implement custom file export functionality as needed by specific implementations. Along with this out of the box batch control, cloud services also provide related objects (such as scripts.) that also can be used as templates while creating custom export processes.
Please note that the main data extraction logic lies within the script as described below. Customer can look at and copy the F1-GenProcEx script to implement their own data extraction logic.
This guide will follow a "bottom up" approach regarding the creation and configuration of cloud service data and objects to facilitate the file export process. The first step is to create a data area and script using that data area. Other objects for the file export will be created next.
For this sample implementation, we will export Premise information from Customer Cloud Service to Object Storage. This involves creating two algorithms (one for file export and one for selecting records to export) and a batch control.
To create a File Export Algorithm:
1. Create a data area that defines the schema for holding premise information.
2. Create a Plug-in script with the Batch Control - Process Record Algorithm Entity. This script may be based on the F1-GenProcEx script and modified as needed. Make sure to use the data area created above to hold premise information.
The script will be used by the algorithm that will perform the file export.
3. Create an Algorithm Type similar to F1-GENPROCEX, based on the plug-in script created in the last step.
4. Create an algorithm based on the algorithm type.
To create a record selection algorithm:
1. Duplicate the F1-GENPROCSR algorithm to create a custom algorithm that will be used for selecting records.
2. Update the algorithm’s parameters.
• Use the SQL parameter name to define the new query for retrieving records from the cloud service database.
• Keep the Batch Strategy parameter as THDS.
• Define the key field on the query under the Key Field parameter.
To create a batch control:
1. Duplicate the F1-PDBEX batch control to create a new batch control. Navigate to Algorithms tab on the batch control and replace the existing algorithms with the file export and record selection algorithms created above.
2. This newly created batch control contains parameters for file storage that must be modified as described in the following section.
