When to Customize
The layout of the legacy extract files should be finalized as soon as possible, to provide enough time for the extract process development.
The setup of the batch job chains is less critical at the beginning of the project. The initial suggested setup is likely to be included in the application Conversion Accelerator. Adjust the initial setup after you've performed the trial uploads of the actual data, assessed the performance and figured the optimal flows.
