| Object Type | Description | Remediation Advice |
| Database Sequences | Sequences stored on the database used for identifier or other processing | Migrate code to use F1-DocumenSequenceAddUpd business service for sequence maintenance  |
| JSP  | These are code-complete screens written exclusively in JSP format | These need to be migrated to use UI Maps with simplified JSP code |
| JSP User Extensions | These are code snippets for legacy JSP based screens to override behavior on those screens | Not supported at the present time |
| FILE-PATH | Specifications of raw directories on the machine for batch processing. For example, directories to read or write files | Migrate to use aliases using the Cloud Object Storage Adapter |
| Environment Settings | Settings in various files in the architecture | Not supported as service provides the environment preconfigured.  |
| Custom Threadpool definitions | Settings and architecture of batch execution threadpools | Migrate to use DEFAULT |
| Configuration Data (Admin Menu) | Administration menu data | Migratable using Content Migration Assistant |
| PL/SQL Code | Custom pl/sql functions | Not supported for security reasons |
| Triggers | Custom code on database | Not supported for security reasons |
| Other database objects | Other database objects that are not listed in the Custom Table support | Not supported |
| Linux/Unix Scripts | Custom scripts to manage the service | Not supported as service takes on that responsibility |
| Custom WS-Policies | Custom policies for inbound and outbound integration | Not supported as service provides prebuilt security |
| Oracle Web Services Manager policies | Web Service Manager policies for inbound and outbound integration | Not supported as service provides prebuilt security |
| Oracle WebLogic Domain configuration | Domain Configuration for WebLogic | Not supported as service has prebuilt architecture |
| Custom Logo | Custom logo on service | Use Domain name for environment identification. Custom Logos are not supported as rebranding is not supported. |
| Custom Product Name | Custom name of product on top of screens | Not supported |
