Go-Live Checklist
The following items are things to consider as your implementation prepares for go-live:
•	Refer to Chapter 6: Information Life Cycle Management and Archiving in the Oracle Utilities Cloud Services Live Operations Guide for details regarding batch processing used with information lifecycle management.
•	Make sure that you have current month and 1 future month partitions already created.
•	The data conversion process has set the ILM_DT and ILM_ARCHIVE_SW as 'Y' for historical data. Please make sure that the PMAX partition is empty after the data conversion is completed.
•	Make sure that all historical partitions excluding Measurement objects (D1-MSRMT and D1-MSRMT-Log, we do sorting based on MC_ID during compression for better application performance) should be in HCC.
•	Cutover activities may include measurement compression batch run which will compress Historical Measurement (D1-MSRMT and D1-MSRMT-Log) partitions during cut-over period.
•	Scheduler batch streams are configured to run ILM batch jobs on monthly basis.
