Batch Job Scheduling
Using SaaS Batch Scheduler
The SaaS Batch Scheduler is provided with Oracle Utilities cloud services and is the default job scheduling option.
SaaS Batch Scheduler is a feature in Oracle Utilities Cloud Service Foundation that provides a SaaS batch scheduler engine and user interfaces. It facilitates customers and implementers to define, manage and schedule stream of batch jobs to run at periodic intervals using a user friendly interface. The SaaS batch scheduler engine is responsible for scheduling and processing the stream of batch jobs. It has a processing loop that runs every X seconds (configured by default at 10 seconds) to perform these operations. In addition, users can monitor the progress of the streams, each of the steps and also perform required exception handling. The SaaS batch scheduler engine processes the stream of batch jobs per scheduled time, within that minute.
Pausing Scheduler Batch Streams
Holding the execution of Scheduler Batch Streams is fully supported.
Future Scheduler Batch Streams
Scheduling a Scheduler Batch Streams to be effective in future is fully supported.
