Code and Configuration Migration
All automated configuration migration between environments should be done using Content Migration Assistant (CMA) provided with the Oracle Utilities Application Framework. An automation option for configuration migration, called the Process Automation Tool, is supplied through Cloud Service Foundation (CSF) included in all Oracle Utilities cloud services.
Note: Migrating data between environments on different cloud service release versions using Content Migration Assistant (CMA), for example, importing data exported from a 23C environment into a 24A environment, may result in import errors in some circumstances. Refer to Versions and CMA in the Administrative User Guide for more information about specific use cases where errors may occur.
What is Cloud Service Foundation?
Cloud Service Foundation (CSF) is an add-on companion product for Oracle Utilities cloud services that provides automation for various generic processes, such as configuration migration. It is installed on top of the Oracle Utilities Application Framework in the same primary application installation in the cloud.
Infrastructure Process Types are provided out-of-the-box to support CMA Accelerator Load and CMA Migration processes (extract from one cloud environment and import into target). More information about CMA and Process Automation Tool is available in the relevant Administrative User Guide for each cloud service.
Refer to Content Migration Assistant (CMA) in the Administrative User Guide or the online help and Process Automation Tool in the Oracle Utilities Cloud Service Foundation Administrative User Guide for more information.
The Process Automation Tool provides several migration requests with the base package that orchestrate migration of objects based on appropriate criteria. Alternatively, you can create custom migration requests to select appropriate records based on specific business requirements. To see the migration requests provided by the product, log in to the relevant cloud service application and navigate to the migration request page by selecting Admin, then Implementation Tools, then Migration Request, then Search.
