Conventions
The following text conventions are used in this document:
Convention
Meaning
boldface
Boldface type indicates graphical user interface elements associated with an action, or terms defined in text or the glossary.
italic
Italic type indicates book titles, emphasis, or placeholder variables for which you supply particular values.
monospace
Monospace type indicates commands within a paragraph, URLs, code in examples, text that appears on the screen, or text that you enter.
Notes:
Screen images in this document are for illustrative purposes only.
Menu options in this document assume the use of Alphabetic sorting. If alternatives are used, then adjust the advice accordingly.
