Go-Live Checklist
The following items are things to consider as your implementation prepares for go-live:
Refer to Chapter 6: Information Lifecycle Management in the Oracle Utilities Cloud Services Live Operations Guide for details regarding batch processing used with information lifecycle management.
The data conversion process has set the ILM_DT and ILM_ARCHIVE_SW as 'Y' for historical data. Please make sure that the PMAX partition is empty after the data conversion is completed.
Make sure that all historical partitions excluding Measurement objects (D1-MSRMT and D1-MSRMT-Log, we do sorting based on MC_ID during compression for better application performance) should be in HCC.
Cutover activities may include measurement compression batch processing which will compress Historical Measurement (D1-MSRMT and D1-MSRMT-Log) partitions during cut-over period.
Drop partition batch processing can be used to drop empty partitions as/if needed to save on database storage.
Scheduler batch streams are configured to run ILM crawler and compression batch jobs on monthly basis.
