Privileged Users
By default, the Oracle Utilities Cloud Services delivers a single initial privileged user SYSUSER in the installation. This user was intended to be used solely to add other initial users into your service. As this role is now provided by the Oracle Cloud Infrastructure Identity and Access Management solution provided with the service, the SYSUSER user is now delivered disabled by default.
For backward compatibility purposes, you may request to temporarily re-enable this user to migrate any configuration over to other users in this release. In future releases, the ability to re-enable the user will be revoked.
