Environments and Quotas
The number of environments you can request is controlled by your account's quota. The quota is determined according to your cloud subscription initial order and subsequent update orders.
Typically, all Oracle Energy and Water cloud services subscriptions entitle you to:
- One Production environment
- One Pre-Production environment
- One Development environment
Additional environments included in the initial order or subsequent orders will be classified as:
- Additional Development environment
- Additional Test environment
- Additional Pre-Production environment
- Additional Training environment
These additional environments will have their own quota and will not be counted together with your initial Development and Pre-Production environments.
Update orders will automatically update your account quota and will not require any special action. When additional environments are needed, you should create new requests in App Manager according to the quota you have. If your request, exceeds the quota you have, it will be rejected.
For example, if your initial subscription order included the cloud service base part, one additional development environment, and one additional pre-production environment, you can create the following environments in App Manager:
- One Development
- One Production
- One Additional Development (same as a Development environment but counted separately in terms of your quota)
- One Additional Pre-Production (same as a Pre-Production environment but counted separately in terms of your quota)
