Oracle Energy and Water SaaS Subscription and OCI Services
Each Oracle Energy and Water cloud service subscription must be accompanied by an Oracle Cloud Infrastructure (Universal Credit Model) subscription or a subscription for Oracle Cloud Infrastructure selected services (including at a minimum Object Storage).
- If you do not have an existing account for Oracle Cloud Infrastructure services, you
will likely go thought the activation process twice:
- One activation will be for your Oracle Energy and Water services
- One activation will be for your Oracle Cloud Infrastructure services
- Since the order of the activation can vary, you should:
- Create a new cloud account on the first activation (whichever subscription it is for).
- After the cloud account for the first activation was created and provisioning was completed, add the services in the second activation to the account created by the first activation.
- If your first activation is not for the Oracle Energy and Water service, remember to apply all the considerations for administration users and home region as if it was for the Oracle Energy and Water service. This is since in the end both subscriptions will reside in the same cloud account, using the same default identity domain and the same home region.
- If you already have an existing subscription to Oracle Cloud Infrastructure services
and you are planning to use these services for your new Oracle Energy and Water
subscription (e.g. Oracle Energy and Water cloud services require access to Object
Storage in order to exchange file for integration and data conversion) then you should
activate your new subscriptions into that existing cloud account.
- In this case you should still consider the home region of the existing account
and whether it is in sync with the planned provisioned region of your new cloud
services.
- If it is not the same, you will have to weigh the possible network latency in identity management access vs getting an additional subscription for Oracle Cloud Infrastructure services and adding that to the new account you will create for your new Oracle Energy and Water services.
services.
The following diagram (see Figure 3.3) illustrates a case of an Oracle Energy and Water cloud service that was activated into a new cloud account. And a subsequent subscription for Oracle Cloud Infrastructure services (e.g. Object Storage) which was activated into the same account.
Figure 3-3 Account with SaaS and OCI Services
In this case the Object Storage OCI service was added to your Oracle Energy and Water service in the same cloud account. Object Storage is also a regional service so it can be used in any of the regions that the account subscribes to.
