Process Starting Point
Once your sales order has been processed and booked in the system, an activation email will be sent to start the process.
The Activation Email
The email will be sent to the administrator, or the owner noted on the sales order. if your order contained multiple subscriptions, each subscription would have its own activation email and therefore its own activation process.
The activation email will be typically sent on the subscription start date or one day before that. This means that if your subscription starts in a future date, you will not see the activation email until that day or a day before that. If you order contains multiple subscription with a different start date, you will get multiple activation emails at different dates.
The email will be from "Oracle Cloud" and will a subject title of "Action Required: Welcome to New Oracle Cloud Service Subscription(s)"
Please note that this is subject to change and might not be the exact sender name or subject title.
Parallel Subscription Activation
If your order contains multiple subscriptions, all starting at the same time, and you plan to host them all in the same cloud account, it is highly recommended to go through each of the activation processes only after the previous one has been completed and fully provisioned. If, on the other hand, you are planning to host each of your subscriptions in a different account, you can activate them all at the same time.
In the process description below, we will assume that you are the administrator and therefore you received the email. If you are not the intended administrator for this subscription you can forward the email to whoever is the intended administrator to continue the process.
