Licensing Information
Product
Subproduct
Oracle Utilities Smart Grid Gateway
Oracle Utilities Smart Grid Gateway provides the core functionality for measurement data and device event loading and processing, and issuing and tracking smart meter command requests. Supported commands include: Remote Connect, Remote Disconnect, Commission Device, Decommission Device, On-Demand Read, Device Status Check, and Demand Reset.
Included Products:
Oracle Utilities Service and Measurement Data Foundation
Prerequisites:
• Oracle Database Enterprise Edition
• Oracle WebLogic Server Enterprise Edition
• Oracle SOA Suite (BPEL)
• Oracle Service Bus
Restrictions:
The Oracle Utilities Service and Measurement Data Foundation provides functionality used by multiple Oracle Utilities products, including Oracle Utilities Meter Data Management and Oracle Utilities Smart Grid Gateway. Some of the functionality provided with the Oracle Utilities Service and Measurement Data Foundation is restricted, and can only be used if specific products have been licensed. See License Restrictions Matrix for more information.
Oracle Utilities Information Lifecycle Management for Meter Data
Oracle Utilities Information Lifecycle Management for Meter Data contains a set of processes to support Information Lifecycle Management (ILM) for a number of high volume transactional data objects. The processes identify eligible historical records to facilitate the migration of data to lower cost storage or archived database.
Prerequisites:
• Oracle Database Enterprise Edition and the Partitioning option are prerequisites for this option.
Oracle Utilities Smart Grid Gateway Adapter Development Kit
Provides the ability to configure standards-based integration to AMI head-end systems not currently supported by Oracle Utilities Smart Grid Gateway productized adapters, and enables integration with both AMI and AMR systems to support both data loading and smart meter command integration.
Supported commands include Remote Connect, Remote Disconnect, Meter Commissioning, Meter Decommissioning, Device Status Check/Meter Ping, and On-Demand Read.
Oracle Utilities Smart Grid Gateway Adapter for Landis+Gyr
Provides productized smart command integration with Landis + Gyr Gridstream Command Center, and converts Landis + Gyr measurement and device event data into a unified data format for use by downstream applications such as Oracle Utilities Meter Data Management.
Supported commands include Remote Connect, Remote Disconnect, Meter Commissioning, Meter Decommissioning, Meter Retirement, Device Status Check/Meter Ping, On-Demand Read, and Demand Reset.
Oracle Utilities Smart Grid Gateway Adapter for Echelon
Provides productized smart meter integration to Echelon NES., and converts bulk usage and event data from the Echelon XML format into a unified data format for use by downstream applications such as Oracle Utilities Meter Data Management.
Oracle Utilities Smart Grid Gateway MV-90 Adapter for Itron
Supports conversion of MV-90 binary measurement data and interval status codes for use by downstream applications such as Oracle Utilities Meter Data Management.
Oracle Utilities Smart Grid Gateway Adapter for Sensus RNI
Provides productized smart meter integration to Sensus RNI and converts usage and event data from the Sensus RNI specific format into a unified data format for use by downstream applications such as Oracle Utilities Meter Data Management.
Oracle Utilities Smart Grid Gateway Adapter for Silver Spring Networks
Provides productized smart meter integration to Silver Spring Networks Utility IQ, and converts usage and event data from the Silver Spring Networks format into a unified data format for use by downstream applications such as Oracle Utilities Meter Data Management.
Oracle Utilities Smart Grid Gateway Adapter for Itron OpenWay
Provides productized smart meter integration to the Itron OpenWay head-end system, and converts usage and event data from the Itron OpenWay format into a unified data format for use by downstream applications such as Oracle Utilities Meter Data Management. Also provides a mechanism to regularly schedule requests of this data.
Oracle Utilities Service Order Management
Provides orchestration of service orders that involve field work and/or smart meter commands through integration with customer information systems, mobile field work systems, and head-end systems. Supported types of service orders include:
• Enable / Disable Service
• Disconnect for Non-Payment / Reconnect for Payment
• Meter Exchange
• Move In / Move Out
