Supported Integrations
The following integration is supported in this version of Oracle Utilities Smart Grid Gateway.
Note: Version numbers listed below are supported as of the v2.5.0.0.0. release (April 2021). Refer to the Certification Matrix for Oracle Utilities Products (Document ID 1454143.1) on My Oracle Support to determine if support for newer versions of the listed products have been added.
Oracle Utilities Product Integrations
• Oracle Utilities Smart Grid Gateway V2.5.0.0.0 to Oracle Utilities Network Management System V2.4.0.x, V2.5.0.x (Oracle Utilities Integration for Outage Operations)
• Oracle Utilities Customer Care and Billing (V2.7.0.x, V2.8.0.0) Integration to Oracle Utilities Service Order Management (V2.5.0.0.0)
• Oracle Utilities Mobile Workforce Management (V2.3.0.x+, V2.2.0.3) Integration to Oracle Utilities Service Order Management (V2.5.0.0.0)
