Secure Communications (SSL)
By default, Oracle Utilities Smart Grid Gateway uses HTTPS to communicate to the browser and across the tiers. The transport protocol can be encrypted using SSL/TLS to secure transmission of data across networks.
Note: Oracle strongly recommends that customers use SSL to secure transmission for production environments.
To implement SSL the following process must be completed:
1. Configure Oracle WebLogic to use the SSL protocol. For Oracle WebLogic customers refer to Configuring SSL in Oracle Fusion Middleware Securing Oracle WebLogic Server.
2. Set the SSL Port Number using the WEB_WLSSLPORT configuration parameter as outlined in the product Server Administration Guide.
3. Once the setup has been tested and verified refer to the console documentation on disabling insecure protocols.
