By default, the database administration account as SQL Data Manipulation Language (DML) access to Oracle Utilities Smart Grid Gateway schema, as dictated by the default permissions of the Oracle Database. It is possible to restrict the permissions of the DBA to SQL Data Definition Language (DDL) statements only using Database Vault. Refer to the
Database Vault Administrators Guide for details of this facility.
The product includes a prebuilt database vault solution, refer to the
Database Vault Integration (Doc Id:
1290700.1) available from
My Oracle Support.
