coherence-cache.config.xml
The coherence-cache.config.xml file is generated using the coherence-cache.config.xml.template located in the templates directory.
The format and structure are set up for the implementation of Oracle Coherence for the batch infrastructure within the product.
Note: This file is fixed in format and should not be altered unless instructed by Oracle Support.
