Landis+Gyr Command Flows
The table below lists the communication flows used with each Landis+Gyr command, including:
• Command: The specific smart meter command
• Outbound Communication: The outbound communication business object created by the command. This sends the command request to the head end system.
• Inbound Communication: The inbound communication created by the response from the head end system
• Completion Event: The completion event(s) triggered by the command, if any. Completion events are used to update data in the system as a result of a smart meter command. For example, if a command changes the status of a device, the completion event is responsible for making that change.
Command
Completion Event
Device Commissioning
L+G Add Meter to Inventory(MultiSpeak)
(D3-AddMeterToInventryMultiSpDR)
Device Commissioning Completion Event
Device Decommissioning
L+G Meter Remove Notification (MultiSpeak)
(D3-MtrRmvNotifMultiSpeakDR)
Device Decommissioning Completion Event
Meter Retire
L+G Meter Retire Notification
(D3-MeterRetireNotificationDR)
Meter Exchange
L+G Meter Exchange Notification
(D3-MeterExNotificatnMultiSpDR)
Remote Connect
L+G Initiate Connect Disconnect DR
(D3-InitiateConnectDisconnectDR)
Con/Discon State Change Notif-Direct Route
(D3-ConnectDisconStateChgNtfDR)
Connect Device Completion Event
Remote Disconnect
Disconnect Device Completion Event
Demand Reset
L+G Schedule Demand Reset (Multispeak)
(D3-ScheduleDemandResetDR)
Reading Changed Notification Direct Route
(D3-ReadingChgNotificationDR)
On-Demand Read (MultiSpeak)
L+G MultiSpeak Initiate Meter Read By Meter Num Direct Route
(D3-InitiateMRByMtrNbrDR)
Create IMD Completion Event
On-Demand Read (Interval) [CIM]
CIM Meter On Demand Read Direct Route (Interval)
(D3-CIMGetLPDataDR)
CIM AsyncReply MeterReads Direct Route
(D3-CIMAsyncReplyMeterReadingDR)
On-Demand Read (Scalar) [CIM]
CIM Meter On Demand Read Direct Route (Scalar)
(D3-CIMMeterOnDemandReadDR)
Device Status Check
CIM Ping Direct Route
(D3-CIMPingDR)
